I used a Knockoff greddy ITB plenum, then took apart and gutted the throttle bodies, i used freeze plugs and sealant to plug the holes from the shafts/seal assmblies.
Tig welded up a few vacuum outlets that will no longer be used. I used a mustang 90mm edelbrock throttle body which i wont recommend to anybody for a boosted application. welded on a throttle body flange, port matched everything and were in buisness. I also shaved off all the mounts for ITB throttle linkage and welded on a new throttle cable bracket..
heres the pictures
