BNR034 »
https://forums.nicoclub.com/bnr034-u131871.html
Sat Apr 18, 2009 6:55 am
Hey im new to here just wanna hear your thorts on my rb26 build? im going for responce and abit of high end aim is over 500rwhp.
ENGINE / TURBINE
TOMEI ARMS B7660 Turbo Kit TOMEI EXPREME Turbine Outlet PipeTOMEI EXPreme Exhaust Manifold TOMEI Heavy Duty Timing Belt TOMEI Valve Springs TOMEI Valve Guide Set TOMEI Adjust Pulley TOMEI PROCAM Camshaft Intake. MID Type. 260 degrees duration, 10.25mm lift. Exhaust. MID Type. 260 degrees duration, 10.25mm lift.
TOMEI Reinforced Con Rod Bolts TOMEI Forged H-Beam Conrod Kit TOMEI Gasket Combination TOMEI Forged PistonsTOMEI High Performance Oil Pump for RB26 TOMEI Oversize Oil Pan for RB26 TOMEI Cooling Channel Forged Piston Kit TOMEI Head Studs TOMEI Reinforced Cam Cap Studs RB26DETT TRUST GReddy Crank Cap Bolt Nut Set HKS Fuel Pump Ugrade HKS Fuel Delivery Kit HKS Adjustable Fuel Regulator
HKS 1000cc Injector NISMO Bearing Connecting Rod Set 1 NISMO Oil Separator NISMO Intake Plenum
SplitFire Super Direct Ignition System
COOLING / Intake
NISMO Air Flow Meter ARC Super Blow Off Valve ARC Super Induction Box ARC Oil Cooler Kit ARC Engine Oil Cooler Kit ARC Oil Cooler Rear Differential Oil Cooler KitARC Intercooler Kit ARC Radiator Hood Panel ARC Radiator Hood PanelARC Radiator Set ARC Thermostat
Havent thort about what ecu im going to be running yet was thinking maybe a power fc
