YOU SIR JUST CLEARED UP ALOT FOR ME..but i think the boost gauge is working cause it is showing like 2 bars of vaccum hahahah...and as for the poppin that crap is annoying as s***...i dunno wtf to do about it...but i put on the maf and for the time it did start a little it started to pop when i gave it a little gas before the gas ran out so i dunno...i am gonna change out the old oil again and see what i get...i think there are probably still some blockage or aka old build up so maybe if it gets a good run it will clear it up somewhat i hope and i think i am losing vaccum from the throttle body where i used silcone to seal it to the intakeXit40 wrote:First I would check the gauge to make sure it's working correctly. I had the same thing happen to me, 0 vac/boost on the gauge no matter what I did. It turns out the boost gauge line was pinched behind the gauge in the A Pillar Pod. Sounds dumb I know, but check out the line and gauge first.
Second Do a boost leak test to see if/where you have any vacuum/boost leaks. Check everything after the MAF. Listen for air escaping, move things around to see if it changes anything and use some soapy water to locate harder to hear/find leaks. You'll usually find leaks from the fuel injectors, TPS Sensor, Intake Manifold gasket, vacuum hoses/nipples, intercooler couplers, etc.
Those two steps should pinpoint any intake problems you have. If you feel it's still not running right after that go ahead and do a compression test and a leakdown test if you find something wrong. The fact that it starts and runs signifies that you have at least decent compression.
The popping your hearing probably has to do with the fact that it was running in safe mode since you had the MAF unhooked. Most likely just the hot turbo burning off unburned fuel vapors since it runs SUPER rich in safe mode. It should clear up on it's own when you install and hook up the new MAF
hahaha i like that part about the lungs...but yeah the gauge works cause each time i tighten something i see more vaccums hahahaha...i think i sold that problem but now the maf is acting up smh when i plug in the car revs really high then diesl0nestar wrote:Make sure your gauge is working.. what is your source? Is your gauge electronic (uses a sender) or mechanical (have to run a vacuum line into the cabin)?
Either way, use a hand vacuum pump (or your lungs) and test the gauge out that way.
hahaha i like the one about the lungsl0nestar wrote:Make sure your gauge is working.. what is your source? Is your gauge electronic (uses a sender) or mechanical (have to run a vacuum line into the cabin)?
