Ok, lesson learned, Don't take on big messy car projects in 1)a gated community with neighbors that complain 2)your friends PARENTS house 3)anywhere where you have a time limit of 1 weekend for a first time swap. ok, whatever. . .i ate those $100, learned my lesson. Now being in southern california, i am spoiled with shops everywhere, good and bad. Ok, i say f*** it and splurge, i take it to a very reputable shop with guys who know what they're doing since they do these swaps all day long. So anywho, another $100 tow truck bill gets my car to the shop. Now here's the doozy. . .the tow truck drops my car off right?. . ..then backs into it right before he leaves. ..lol! I'm like wtf??!! Well, he's taking care of the bill once the car comes out of the shop. I'll probably just end up getting a carbon fiber unit rather then repair and respray the stock one. ..who knows. on with the story. . .
$2500 for the swap. ...install the motor,do the wiring, install Greddy Intake Manifold and Q45 TB, FMIC piping and install Mckinney Motormounts and driveshaft(which were included in the price and installed flawlessly btw). Time was great. .it only took a few days to drop in the motor and get it wired up. I got that call, your car is ready to pick up! I was stoked to say the least.
When i drove it home, it felt kind of funny(no power) but was afraid my expectations might of been too high so i drove it home anyway(not that far). I called the shop and told them my concern and they told me to bring it on down to make sure everything was cool. So i said great! I take it a day later and end up overheating by the time i get there. Now thats my fault because i provided the fan they used which was enough for my Turbo 4cyl but not this car. luckily, it wasn't THAT bad to cause damage. Since we were running on no guages he said it'd be a good idea to install these so we know whats going on (which makes plenty of sense to me and i agreed) I bought a water temp, boost pressure, and oil pressure.
oh yeah, before i forget. I got the car back with no knock sensor harness! apparently, my clip didnt come with one? I was really tripped out but luckily got one off my friends extra RB20 harness and ran it straight to the ecu since i couldnt find the plug that contains the sheilded wire for the knock sensors
I took the car home later (once the temp came down from this sunny 100 degree cali weather). eventually got around to install them and install another better fan. Overheating solved
Idle is weird. It drops sometimes temporarily and sometimes seem to be searching for idle. I have no BOV right now so im getting some MASSIVE compressor surge
The other day, i took my intercooler off just out of a hunch and found oil puddled in the endtanks. enough to drop out when you hold the intercooler sideways on both sides. I immediately thought turbo but it has no problem holding boost pressure at 7lbs. There is no smoke coming out of the tailpipe at all. I cleaned it up and drove it hard for a day then checked again, nothing. weird! My friend brought up a faulty PVC causing blowby from the valve cover going back into the intake stream which is also possible. Anyone know how to check for a faulty PVC? and where to replace it?
The other/main thing is power. The turbo spools, holds boost, but just doesnt go! I mean, it doesnt have nearly the power and torque that an inline 6 turbo motor should be capable of. My friend has a turbo from a spare RB20 that i'm thinking of swapping just to see if its possible the turbo could be causing me any greif. I haven't done a compression test since i purchased the motor when it read around 140 with less then 5 variance across all cylinders (done motor cold and in clip before i purchased it) I've also done the infamous carb cleaner can in search of leaks on vital motor gaskets. ECU shows 55, all good in my neighborhood!
If someone in socal has some good deeds to claim i could sure use some help. Anyone have any tips online they could help me with and should try i would GREATLY appreciate it. In the meantime, i have some schoolwork that needs attending(college boy). thanks for taking the time to read my journey into the land of RB25. any and all responses welcome. thank you
Rafael Gonzalez
