Hustle240 »
https://forums.nicoclub.com/hustle240-u56418.html
Sat Jun 28, 2008 10:38 am
After trying to sell, I decided to keep it and put some work into it. As of now this is how it sits.
RB25DET Swap Runs PerfectMcKinney Motor and transmission MountsMcKinney DownpipeMcKinney Steel One Piece Driveshaft3" Testpipe and CatbackMcKinney IntercoolerGreddy type RS BOVRB Gauge Cluster
Parts just order:Z32 MAFIntake ManifoldJim Wolf Clutch/FlywheelJim Wolf Tuned ECUJim Wolf 55 lb MSD InjectorsQ45 Throttle BodySAFCMcKinney RadiatorGarrett GT3076R TurboBuddy Club Spec II ExhaustKAAZ 2 Way LSDStance GR+ Coilovers38mm Tial Wastegate
Getting ready to pull the motor again, paint the motor and do a wire tuck. Then all the parts should go on.
Now, I know I am going with the Kouki front end conversion but I'm debating on which body kit to go with. Sooo, any ideas would be appreciated on that. Also, I want to get some wheels with a nasty lip on them, but don't require widebody. ( Not a widebody fan). Sooo, again... any help from you guys would be helpful.
When I pull the motor and start on my stuff I will post pictures of progress.
**EDIT**: After seeing a few pictures of verts with the kouki front, it looks as if they all are widebody some.. and they didn't look that bad (at least the ones that weren't crazy wide). So I may consider it, but not sure on how wide to go.
Modified by Hustle240 at 3:28 PM 6/28/2008
