When it randomly starts does it continue until you shut it off or does it go away?If you can get it to consistently do that then pull a plug wire one at a time until you notice that when you pull 1 out of the 4 nothing changes. Then you know which one is misfiring and you can take it from there..zerodameaon wrote:So i know a bit about RBs but i haven't ever had this problem before. When im driving my or having just started the car, will randomly start sounding like a Subaru. iv searched around a bit but i only found one thread that didn't really answer what the problem was. and the crappy thing is i cant pull codes because my ECU is one of those remand ones that doesn't have the screw or LEDs. and i cant find out how to make it use the Check engine light. Any help or even a point in the right direction would be appreciated.
Ah I didn't see it was an RB..ANVIL wrote:1 out of 6 coilpacks. not plug wires.
but yeah, good advice otherwise. check the plugs, and the gap. if u can get it to make the sound, unplug one coilpack at a time. if u need more help you can probably better answers if u posted up in the RB section
I just got some coils off a Q45 with 50000mi on it so im going to find out which coil might be bad and change it out. once i can get my hands on a J30 im going to get me a second ignitor and see if the problem goes away.Coolwhip wrote:check your coil pack ignition sub-harness that connects to the coils. Make sure the plug connectors are snug and that there isn't any build up of corrosion on any terminals. The harness usually gets backed in between the rocker covers and trapped under the coil cover, so it should feel pretty crispy (the harness). Might want to break open the harness and check the wires, could have some wiring that just isn't up to par like it use to and as it gets hot or wiggles the wrong way, you start to lose that cylinder.
As well, assuming this is a Series 1 RB25, make sure that the ignitor chip is away from extreme heat sources. Things get funky around heat.
What you heard is correct. only cylinders 1 and 2 work. the rest are lot diffrent.ANVIL wrote:does any coil from a q45 work? is it a direct replacement? i read somewhere it was a certain cylinder coil from the q45 is the same as rbs
