my rb25 has me puzzeled, wierd idle problems please help
captainclutchkick
Car: 1990 nissan 240sx coupe with rb25det
my series 2 rb25det with a greddy intake manifold an q45tb idles all f'd up. the car idles at about 1200 rpm and then hicups every now and then but the big problem is that when its idleing at about 12oo rpm it will start to rev on its own until about 2500 rpm then it quits and revs beck at 1200 rpm again it does this all the timne? almost like im steadily pushing the pedal down until 2500 rpm then letting off ??? any ideas on what this may be? im thinking my q45 tb is wired wrong but i cant find anything on the net about how to wire a q45 tb to a series 2 rb25? or could it be my tps???
please help me i need to get this car going?
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
what about the air ideal control? That could also cause the problem
integra7
Car: 1995 Nissan 240sx
have you removed the fast idle hardware from the q45 throttle body?
captainclutchkick
im not shure jgy customs did a horable job on my swap i really dont know what they hell they did, it looks as if they used my car as a learniing tool to figure out how to do the swap. please explain how to remove this or how i can check to see if its removed1
captainclutchkick
anyone a little help?
ISUJinX
1. Check for vaccuum leaks. 2. Check for boost leaks.3. Check your MAF hookup (especially the grounding wire)4. Make sure your TPS is set properly (look at your butterfly valve on the TB)5. Clean your IACV (Idle air control valve) theres threads about it.6. Check the position of your TPS at Idle (butterfly valve)7. Make sure your throttle cable isn't too tight.
Thats a kinda random order list of stuff to check. Theres other stuff like high fuel pressure, might be an idle setting on the RB ECU (don't know for sure and I dont feel like walking to my garage).
