my rb25 240sx not starting need help
araelzx2
Car: 95 240sx
hey guys im just finishing my 95 240sx with an rb25det series 1 but i crank the motor does not start and it seems that gas is not getting to the motor the fuel pump is working cus i can hear it goin on any ideas the ecu has power and everything o another question those the white plug from the rb harness just plugs to the 240sx harness thats the one inside the car ????
ANVIL
Car: RB25DET S13.5
well, confirm the fuel with a fuel pressure gauge, or pull the line off and turn the key on and see if fuel comes out. then u can also see if the injectors are firing.
araelzx2
Car: 95 240sx
hey today i spend the whole day finishing the wiring there is fuel going in but the injectors are not firing because there is no ground getting to it i connect a ground cable directly from injector one cable to the batery and the motor started right up but after that i would not start again any ideas what could be happening
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Where did you connect the gray injector power wire for 12V power?
araelzx2
Car: 95 240sx
today i connected the grey cable to the power and the motor started right aways i forgot to conected before but now my problem is that the cars hit fuel cut off really bad in 3rd 4th and 5ft around 2k rpms i think i could be the maf any ideas i can wait to get this on the road man
Cltchkikr7
Car: Silvia
yeah the ecu cuts off the motor at 2k if its not getting a maf signal, check into that first
