**My RB20DET s13 Project**
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
i would just get a jdm one that has the u joint instead of the rubber. you only need the front half of the shaft.
240SXinTX
ok, but where can i get a jdm drive shaft?
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
http://cgi.ebay.com/ebaymotors...ZWD1V
That looks like a complete drive shaft, not sure if its the exact one though. Just trying to help out
Abdo
Car: S13 RB25DET
The OEM DOHC S13 driveshaft should work fine with an RB20, but I'm not so sure of the SOHC. If you don't already have a suitable driveshaft, I recommend you don't buy another OEM unit.. Get a one piece aluminum or steel driveshaft from http://www.driveshaftshop.com/ or any other custom driveshaft manufacturer.
ca18datsun510
sohc and dohc shafts are the same.
sr20det are the same as ca18det.
they will all interchange, but the jdm ones use a third u-joint instead of the rubber.
and yes, if you have an extra 350, i would go with the aluminum 1 piece.
240SXinTX
Hey guys, new issue. I got my mounts in today. Can someone tell how many crossmembers there are and what they do?? i should have on that hold up the transmission right? and another for the motor that has the mounts attached? can someone show me an under car pic of a working vehicle...
Nick51
Car: 90 240sx
another thing on your dirve shaft
you should get it made from that site ^ and have them make it .75" shorter and then get the j30 lsd so you dont run into this problem later down the road with everything in
jrd450r
Car: 1990 RB25DET S13
There are 3 mounts, 2 for the motor, and one trans crossmember mount. The top 2 in this pic are for the engine while the bottom is for the trans.
here you can see the mounts installed on the right side of the motor.
ca18datsun510
Nick51 wrote:another thing on your dirve shaft
no, he should get the normal length shaft, and save his money for a good diff.
Abdo
Car: S13 RB25DET
wtf? i measured mine and added 2"!
240SXinTX
jrd450r wrote:There are 3 mounts, 2 for the motor, and one trans crossmember mount. The top 2 in this pic are for the engine while the bottom is for the trans.
hey thanks man, so there are only two "crossmembers?" one for the motor and one for the trans right?
craz4240
Car: 1995 240sx w/rb20det
Yes thats right.The engine crossmember has holes in it where the engine mounts go through...mount them to the motor before it goes in should be pretty self explanatory.
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
You shouldn't be worried about mounting the mounts. Its all very easy to do. There should be a L and a R on each mount. When you install the mounts you'll see how easy it is. Even the transmission.
240SXinTX
my mounts dont have an l or r on each one... im am so confused.. i have everything ready to go, but i cant figure out the mounts.. i have an rb just hanging and i can get it in.. help gusy..
nizmo zilvia
Heres a pic I got from top hats website.
DriftX
Car: '89 240sx
hell, I dont know, my driveshaft worked fine. keep us updated
240SXinTX
ha okay, i got the mounts toworkk... thanks guys.. i9ll try to have pics up later
240SXinTX
hey guys, update:: some of the new pics are bad quality b/c my camera died and i couldnt find the charger, so the swap pics had to be taken with my phone... but i took some pics after i found my charger....
anywho, the motor is in. now i just need to get the harness done and the drive shaft and i can start her up!!
adam-gtX
how was dealing with jdm engine depot? Do you know where thier located?
240SXinTX
They are located in New Jersey, i think... They are AWESOME to deal with. I am very happy with them... one thing though, my motor did get banged around a bit in transport, and the oil return on the turbo is leaking cus of it, but its not their fault... good guys, especially Junar.
240SXinTX
hey guys, i know some of you noticed that i took the top part of my intake manifold off. Can you tell me where to get that gasket at? i can find the regular intake mani gasket, but i need the one that goes in between the two "halves"
DriftX
Car: '89 240sx
I'm in the same boat looking for just the intake gaskets, but it looks like your going to have to buy the whole kit. You can get a complete kit off ebay for 200 bucks.
And with some of the problems I'm having, you might want to go ahead and do it.
Lower/upper intake gasket, tb gasket and all the gaskets that go to iac ect.
Remember, your motor is 15 years old and those gaskets are probably shot!
240SXinTX
hmm.. you have given me something to think about... maybe i should just get the whole kit and do them all... any good links on the whole kit?
240SXinTX
*** update ***
My project is now in the brave hands of Carl Hernandez. The harness has been shipped, we shall see the results!
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Get the whole kit (engine gasket)... I have two, but I have two motors to "update" so i need them. The kit really comes with everything, so you won't regret it if you have the $ to spare. Don't forget to buy an engine stand, and do it while the motor's out.
Make sure you go through all of your hoses and replace any that are cracking and/or brittle. If you take any of your water lines off replace the copper washers with new ones (hard to find fyi due to size so buy a few of them to have on hand).
240SXinTX
Thanks for the advice, but as the pics show, I already put the motor in...
**update***
McKinney mounts stink!!!!!!!!!!!!!!!!!!!!!!!The mount on the passenger side split apart!! The damn car was just sitting there and the mount broke!!!The guy at McKinney said he would replace it, but I think I may just try to fix it... Ill post pics up later....
DriftX
Car: '89 240sx
You won't be dissapointed when you get your harness back, he does awesome work. Just look at those harnesses at the top of the rb help section, so clean and neat! I wish I would have had him do mine. But it works so w/e!
Keep us updated man! More pix!
As for the mounts, i would send them back and get some new ones!
rbsileighty
If you haven't wired it yet... it's really really easy to take in and out (2hrs or so)... I knew you hadn't wired it yet. You'll thank me later.
Lift the car off the motor with the hoist... much easier and cleaner
digzsublime
Car: 95 S14 w/ LS1.
DriftX wrote:I'm in the same boat looking for just the intake gaskets, but it looks like your going to have to buy the whole kit. You can get a complete kit off ebay for 200 bucks
O.E.M. full gasket sets for cheaper here:
http://www.nismoparts.com/catalog/?section=755
No I don't work for them. I've bought from them and they have great prices and normally have this stuff in stock. Great service and Shay (sp?) is a nice guy to deal with. Seems to know his stuff. Oh and Drift X is right. IMO, it's easier to just replace all the old gaskets and seals while the engine is out of the car. Eventually you'll need to anyway.
240SXinTX
^^^^ thanks man that is a really good site! I updated with some pics of the motor install, sorry they are on my phone though
