s14-240 wrote:I got my rb20det to start today, but it is having problems. 1. When I turn on the car with it in gear and the clutch in, it moves the car forward.
you should start the car with the clutch pedal pressed down and/or need to be in neutral. why in the world do you want ot start the car while it's in gear?if you pressed the clutch pedal all the way and while in gear, the car moves forward, you may want to check to see if you properly fled the air in your clutch lines, and the slave cylinder fully disengage the clutch properly.
s14-240 wrote:2. The car starts with difficulty, but once it is started it purrs perfectly, but idles at 1500 rpm's.
if it runs and idle high, you need to readjust your idle speed, go to
http://www.240sxonline.com and click under the RB20 manual, and look at the idle adjustment page (Pg 8).
s14-240 wrote:3. I took the car for a test drive, my friend had to push the car while I put it in gear. It shifts seamlessly, as if the clutch is working, but it has alomst no power.
sound like the clutch isn't grabbing. did you changed out the clutch?
s14-240 wrote:It overheats as well.
did you bled the air out of the system properly?
