My RB20det cam angle sensor shaft broke in half! any one had this happen?
soundmonkey
Car: RB20det 240sx
Does any one know where i can get a C.A.S for an RB motor for a good price? I would get one new but there around $400 bucks. Sooo! There for I'm trying to find one for cheap.
Cjmartz2k
Car: Hunting for a '89 GTR now
Contact Raw Brokerage (Coolwhip). If he doesn't have one, let me know and I can get a junkyard one from over here.
Shocker
Car: 89 240sxHB rb26/30
breaking in half? Something had to have been locked up inside of it for that to happen.. I don't see any other way that happened.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
look at the crank shaft pulley as well to see signs of damage. As cases where this has happen the motor was hit in the front. (check your CAS bracket as well as it is prone to breaking under these conditions).
RBKIDD
Car: 92' RBsilvia
07' TBSS
nismoparts.com. i just bought one brand new, $275 shipped.
soundmonkey
Car: RB20det 240sx
I will get some pictures for you guys here soon. It's pretty damn crazy. There wasn't anything locked up on it. it still rotates freely. Thanks for the help all. I'll try and get in touch with coolwhip.
240slidekat
Car: 240sx, 280z, gsxr1000, m3
actually happened to me a few times. i though it was my bracket but it turned out to be that my timing belt was too tight. you might want to check that.
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
Coolwhip wrote:look at the crank shaft pulley as well to see signs of damage. As cases where this has happen the motor was hit in the front. (check your CAS bracket as well as it is prone to breaking under these conditions).
When you say hit int the front,do you mean like in a car accident?Will it be ok to run it like that,i mean what will keep it from happening again?Im paranoid now since my CAS bracket is broke.
wawazat8402
Car: 89 Sil80- RB25DET
Mine was cracked when I got the motor. Had it TIG welded and it cracked again when I wrecked the car. Got it welded yet again and havent run the motor much. I went ahead and bought another one just in case it cracks again. I never had any CAS failures though.
soundmonkey
Car: RB20det 240sx
I'll have to see if my CAS mount has any cracks. I think I'm just going to get a new sensor from nismoparts. You guys think it could just be a factory defect?
soundmonkey
Car: RB20det 240sx
http://s385.photobucket.com/al...key11/
Let me know what you guys think.
Cjmartz2k
$275????? That must be a new price, right?
soundmonkey
Car: RB20det 240sx
Thanks for the links guys. I have a CAS on the way.
soundmonkey
Car: RB20det 240sx
Also does any one know if i can hook up an OBD1 to my 92 240 RB? I might just end up buying a mini laptop with one of the engine management programs on it but even still.
