my rb20det 223whp / 207ft-lbs dyno print out
HybridOne
Car: swaps
I ran this on Sunday. i ended up leaning the engine out some. In the beginning it was running off the chart on the rich side (better safe than sorry). I have no boost controller, but i'm running about 12-13lbs. I have:
FMIC3" downpipeJIC 80mm exhaustSAFCIIcone filteryou girlfiriend riding shotgun
http://www.showcarssuck.com/pr...o.jpg
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
sweet!
Joe
12lbs and only 220whp?
candela
Quote »you girlfiriend riding shotgun[/quote]
:D :ylsuper
Cool numbers home slice...
goofynick6
Car: 1995 S14.5 RB20DET
Looks like you were tuning for 13:1 ? That seems a tad lean, I would think 12.5 or 12:1 would be safer?
Numbers seem pretty good, I'd be curious to see how accurate your boost gauge is.
Nick
Imissmyturbo
Car: Car's, Turbo's, sking
My RB25 made 230 WHP with 10 psi of boost and 3" turboback exhaust. Everything else stock. So I think your #'s are about right for what you have done.
HybridOne
Car: swaps
well...actually my boost leaked down durring the run. After i hit max psi it creeped down to about 8 or 9 lbs. So i basically lost 4 lbs by the time i hit 7500. And the gauge is Blitz id. I think it has to do with the stock bpv, but i heard they are really good. So i'm going back through and checking my new intercooler piping, and then i'm switch to a blitz dd bov.
It might just have to do with the fact that i maxed the turbo out and the engine is pushing i ton of air through, and the turbo isn't keeping up...though thats a wild guess, with no basis whatsoever.
HybridOne
Car: swaps
i was tuning for 12.5 We re-tuned again after those runs to get the ratio closer to 12.5 in the mid rpm range.
gani
Car: cars what else
sweet numbers
Nameless EJ6
Car: What the **** do you think.
pretty good numbers it looks to me. The torque seems nice. i'd do a little more tuning and perhaps work on getting your boost probelms straightened out..
GTR Shop
Car: 180sx RB26 T78, Y31 Gloria VIP + HEAPS of GTRs!
Do yo have a boost trace also (ie when it makes boost etc?Up to 5-6psi whent he boost is coming on you can run 13:1On a RB20 12.5:1 is as far as I'd go.. 12.3:1 makes good power.Timing is the key though.
Imissmyturbo: You should be making more ponies.. is it 10psi boost still at peak power or is it dropping?
aznromeox
So you gonna get some videos for us soon?
Imissmyturbo
It hold 10 psi to redline. Now when I did those dyno runs I didn't have a tach. My ECU that came with my clip wouldn't putout a tach signal so I replaced it with another and the car does feel a bit stronger then before so I think I am maybee making 240WHP. The car went 13.8 @ 104 with a 2.1 60ft.
