MoToG »
https://forums.nicoclub.com/motog-u117462.html
Fri Oct 10, 2008 3:05 pm
PLEASE READ alright well i dropped my bone stock rb20 in my 240 about 3 months ago since my license is suspended i have only took the car out now like 10 times for short rides(5-10) mins max, car ran good for the most part besides no rev limit, and my o2 sensor went bad on like the 7th ride, and my fuel cuts out and gives me rough revs, so to fix that problem with the fuel, i got a hks fuel cut off defender(f.c.d.), i hooked it up and started to tune the f.c.d... so after a few try's i got the tune right and it revved up beautifully and then it happened i revved it up high and the idle went down to normal and the it started sounding like it was only runing on 2 pistons, so i tried reving it up and it wouldnt allow me, it just back fired really ****ing loud so i turned it off and tied to start it... and it wouldnt start. WHAT IT DOES- it does not start the motor turns over a few times and then it feels like the motor freezes like it hits a wall, so 1st thing that came to mind was i revved it to high and skipped the timming belt and bent my valves or somthing like that, so i checked the timing and it was perfect, so i took my spark plugs out and tried turning the motor and it turned fine and didnt hit the wall of doom, so that eliminated timing for sure=) so i put the spark plugs back in and left the coil packs off so i would be getting compression but no spark, so i turned the motor over and it didnt hit the wall, so i put the coil packs on and turned it over again and it hit the wall=( so that means its somthing 2 do with the coil packs right??? im not familiar with the coil pack setup so if any1 knows what might be wrong please get back to me. oh yeah its getting spark and fuel, and i took off the f.c.d. and it still gives me the same prob. thanks for reading this and id appreciate it if sombody could help my name is vince 727-417-7076 is my cell, call me or comment this post please
