The welder is a Miller Syncrowave 250DX. I don't know much about welders, but this one is badass.
rbsileighty wrote:Very nice bud! Very similar to the concept I had in my head actually...
What's the rest of the engine like (cams etc?)... just concerned about the runner length being so short if you're running aggressive cams or aftermarket exh mani. Can't wait to see a dyno graph! When you get a chance would you mind measuring the runner length?
Keep up the good work!!!
The engine is internally stock for now. other than that:
6Boost t3 manifoldKKK K3T 3070MGA turbo(off a Blitz kit)HKS 50mm wastegateSard 550'sZ32 MAFSand of course, the ITB's
As far as the runners go, maybe someone can enlighten me as to how the length affects engine performance. It is a concept I never really understood. All I have been told is that the RB20 doesn't flow enough, and that ITB's/ shorter runners would actually hinder performance. I just don't understand how less restriction, is worse.
Regardless, just like the practicality of a twin turbo RB20, I have to find out for myself
I'll get the length of the runners once I grab the manifold from Adam. He's welding the coolant water neck right now, then we're done with the intake.
Chaos the Xile wrote:where did you get the flanges for the stock intake at? where they one customs or part of the rb26 intake/itb assembly that you hacked and welded to the slock plenum??????
The flanges were custom cut with a waterjet to match the ITB gaskets.
Here's what the intake looks like all welded up and bolted on(in horrible lighting)
I just want it to run again
