goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.html
Sat Nov 06, 2004 5:57 am
Ok, make sure you have the old bushing out of the crank, then pound the new one in with a wooden dowel so as not to damage it, and only pound it as far as it should go..if you go all the way into the crank it will crush the bushing inside because there is an internal step where it is supposed to stop. I pounded mine too far and it crushing it slightly and the trans wouldn't go back on.
ALso, make sure the clutch alignment tool slides into it smoothly, sometimes have to file the bushing down on the inside a bit if it has been pounded in too hard and the end is folded over a little.
That's how to do it
