HORRIBLE UPDATE:
So I looked into my TPS wiring, seems Rich hooked up the correct wires just to the TCS TPS. I hooked the wires from it (+,-, Signal) and BAM! car was running better, I was even able to adjust my CAS and it not spike my IDLE/timing so I was stoked.
Driving around town felt good pulled in all gears and no cut! I didn't get on it fully tho I stopped at work to get a drink before going on a full testdrive. I walk out to my car and my new radiator has a leak! It jumped up and sat against my Power Steering pulley wore a hole into it
I literally just replaced this rad 3 days ago
I take it to a friends on the way the temps were ok and I did another little pull and I saw steam so I thoguht to myself ok Radiator is definitely leaking (assumed higher RPM's made water flow enough to leak out of the hole again) I pull up to my friends and the car dies...we swap the rad with a s13 one and I start my car and it's missing/idles like crap...look and waters flowing out of my exhaust
My new rings are so good there was no water in my oil until I checked it this morning Chocolate Milk. Pulled all my plugs only cylinder #1 spark plug was wet. I guess I shouldn't have used the Head Gasket that came with my engine rebuild kit.
Now I'm going to look into my best HG option I know CarlH will say OEM but I may go Cometic or something metal since the HEAD and BLOCK were just decked not sure yet. I want to pick up some Tomei Cams possibly RawBrokerage has NEO cams and all 25 cams for $575 now so may be a possiblity.
Not sure if I should venture out and have the car sit even longer for me to install a Freddy Manifold but with the NEO I don't really want to make a bracket for my topfeed injector rail, swap the IACV with one from a Sentra and then more than likely get a Q45 MAF for ease of bolting on (tho In those TPS pics I posted you see a NEO TB on the Greddy Mani)
That whole setup plus the new intercooler AND cams would take me forever at my current wages to save for tho and with Nistune about to be installed I more than likely will stick with the OEM Intake manifold just thinking of what I could do since the head and everything else will already be off.
I have such bad luck the day I fix my harness and am ready for my tune 2nd radiator in a week gets ruined and I blow my HG
LMK what you think about the HG and what performance parts I should try and get while I do the work.
Will post pics after the head is off this week
