meet07 wrote:I wouldn't blame the tuner...Just from reading this build thread Tim you either have bad luck or you don't know what your doing. Do like I did and download the FSM. It helps a bunch. Then back probe all of your sensor to the ecu to make sure your getting all the proper readings.
I was wondering if your brake master cylinder was leaking.....If it was leaking along the frame and the scream pipe did what it does best(SCREAM!!) then there goes your flame.
It was my old master and booster from my champagne s14 and I dont believe I have any issue with them. I suppose it could have leaked.
I have to get a multimeter and I can check my sensors.
I admit When I had no TPS hooked up before when it first ran a year ago I was a fool. I do know my way around an engine bay tho, I have had alot of bad luck which I have learned to chalk up to bad life experiences try and learn and move on,
Rich at Daft wired my TPS wrong so I neglected to notice my TPS wasnt actually hooked up I had never seen the NEO TPS talked about when I looked up info about the motor and it looks unlike any TPS I had ever seen. You let me know I didnt have it hooked up so I looked into it.
My thermostat was working just fine and it happened to get stuck closed, my cluster temp gauge either A) doesnt work with the RB temp sensor (almost got a S14 one) B) cluster gauge is broken.
It only went to halfway so I always thought my temps were fine. I hooked up my autometer gauge to the RB sensor and whaalahh I can read my temp.
