You know what. I am thinking it might be a bad solenoid....but then again i am not so sure since i don't think i completely hook up the engine A/T control signal correctly. I mean the turbo went crazy and my rpm rev up high all the way to red-line and i think i can go past red-line but the car seen like it not pulling hard at all. It feel like i lack of power. and one thing that i noticed is that when i stop and then stomp on the gas hard there was no wheel spinning or power behind it....guess it might the timing is off a little or it might be i am running on 4 cylinders instead of all 6 cylinders. Damn!!! putting the motor in isn't hard at all but trying to figure out all the wiring on an automatic and trying to make it run right is pain in the a$$.Vkoslak wrote:If it is stuck in 2nd that is limp mode. 300zx does the same thing. It could be a short somewhere or a bad solenoid.
