Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Tue Oct 23, 2007 3:25 pm
Still no photos but here is an update..
All wiring is done, rebuilt power steering pump, checked timing belt (looked brand spanking new), put the engine in the car (tight fit)
But, when I lifted it up off the crate for the first time, I noticed something...
It was damaged during freight, the oil pan is bent in a little bit, and the oil line is CRUSHED!!!! leaking oil...
So, I need to see if I can replace the line and use the pan, or if I have to replace both...
Ford taurus fans are wired up...
I wired them up as a pusher (they work as puller (from inside the engine bay) or as a pusher (from in front of the radiator))
To wire them as a pusher simply give the GROUND wire power - use a 30 amp inline fuse before attaching to power.
Then, find the highspeed wire by connecting them to the battery and watching it make a dust storm in your garage..
Once you have it, read the guide on making a fan controller which is extremely easy.. just connect the high speed wire to one side of the connector that connects into the thermostat and the other wire coming off the switch ground on your chassis... (when the ground is made, the high speed kicks in, for the ground to be made the thermostat must reach the temp..)
And, the other wire for low speed, simply ground to your chassis!
Ok, to make the fan turn on when the car is running, simply splice it into the thick white wire coming out of the fusebox into the bunch of cables :-)
