lilskyline240 »
https://forums.nicoclub.com/lilskyline240-u33468.html
Fri May 23, 2008 11:47 am
Ok first ill give you a little background on my car. its a 90 coupe that i bought last summer with what was thought to be a bad KA in it. the motor had no power over 4000rpm. Kinda fell on its face. So i bought a new KA24 and swaped it in and turboed it at the same time. This motor STILL had the same problem of no power over 4000rpm. Just falls on its face! So i figure its something with the engine harness or ecu or something so i decide to go with an RB.
so all last winter i did an Rb30 project and finally got it swapped in my car about 2 months ago and running. now this is what pisses me off!! the car has NO POWER OVER 4000RPM!!! im gettin soooo pissed and im bought to just sell this thing and get a Trans AM.
heres a list of what ive all checked:Pressure tested to 20psi for leaksNismo fuel pressure regulator set at 37psi at idle with VacA/F ratio is at 11.7:1 at WOTTiming is right on 15* with TPS disconnectedNew plugs gapped at .028Car idles and drives fine with no weird noisesno miss-firing, back-firing of any kindcompression is 175psi on every cylinderturbo is brand new rebuilt Australian 300zx turbo (slightly larger than rb25)boost holds steady at 7psiVac at 20mm/hg at idlenew Fuel filterwalbro fuel pump
I have run out of things to check. It seems like the problem has to do with my Chassis and not my motor. What could be causing my problem??? the only 2 possible things i can come up with is Grounds or Fuel pump/tank
Firstly my gas tank has some big dents in the underside from the guy before me and a drifting accident but i dont think that could be causing my problem since my Fuel pressure is perfect throughout the RPM range. going up with boost and holding
Second possibility would be my Grounding. I relocated my battery to my trunk when i swaped out my first KA last summer. I have the battery grounded to my trunk and also a 2 gauge wire running from the negative battery terminal to my block. Without this wire the car wouldnt start at all. Then i have a wire coming from the firewall to the head, and one from the frame to the intake manifold. i figure this is enough grounds but i could be wrong.
Please help me fix this problem so i can enjoy the RB like ive been waitin to for the last 8 months..
