my rb doesnt start :(
bloodspread
Car: 1989 240sx fastback and a 2009 Aveo
so after wiring everything together in the 91 240sx that I had bought with the rb in it I swapped the rb20 over to to a clean shell (since the other shell had massive damage to the wheel well and door frame) so I plug everything in and splice together a the few wires that I didn't have a plug for and I have nothing I was able to get the engine to turn over in my red 240 but not in the new one
I turn the key and nothing happens, no clicks no power to ecu, no power to the windows. the only thing that gets power are the door locks and the dome light inside the car. I dont know where to start what should I check first?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
u know step one in the sticky is where u should start. The power terminal cable to the power terminal to the fuse box!
bloodspread
KUILLIN_DRIFTER wrote:u know step one in the sticky is where u should start. The power terminal cable to the power terminal to the fuse box!
thanks for the help, It turns out that I wasn't getting power to the fuse box like you said, and I was missing like 8 fuses lol.
now the car turns over but I don't think im getting any fuel to the engine. what could be the issue there? thanks for all the help
Carryl
did you change the fuel pump in the new shell? getting voltage at the pump? return and supply fuel lines connected correctly?
bloodspread
it has the stock fuel pump (will be changed to a walbro soon) and I did all the fuel lines ( hopefully correctly), and my multimeter is back home in socal while im up here in Davis(norcal) for school. is there any other way to check for voltage at the pump?
USMCgetsome
ok to trouble shoot this start with
FUEL PUMP RELAYECCS RELAY
FUEL PUMP PRIME = when you apply the on swith you should hear the fuel pump primeFUEL PUMP PULSE = you should feel the feed line and feel 3 small pulses
If none of that then use the multimeter to check voltages
after all that check to make sure your 12VDC PLUG to your FUEL INJECTOR harness is plugged in.
bloodspread
the fuel pump works, but I have a leak in the hard line, its a small hole but has some force behind it. can this be the problem?
bloodspread
I also noticed that the fuel lines coming out of the tank felt firm while the ones up front going to the engine still felt soft, so im not sure what the problem is. or what I could do to resolve the problem?
USMCgetsome
might have some blockage. Check the fuel line before the fuel filter. The feed line hooks up to the back of the fuel rail by the coil pack. return line is the one that goes to the fuel pressure regulator.
bloodspread
right again, the fuel lines were hooked up wrong, but now when I turn the key, it turns over and after a few times it just stops? what should I be looking for next? again, thanks for all the help
bloodspread
actually I think I had it right, then I switched it to how I have it in this picture
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
a real easy way is to unhook both fuel lines and route them into a plastic bottle and have someone turn it to ON, see how much fuel you have spit out in a 5 second prime on the fuel pump, or go buy an in-line fuel pressure gauge at a parts store or something.
If that doesnt work, pull out the CAS and with the key ON, rotate the keyway and listen for the injectors pulsing.
USMCgetsome
i agree with kansai.. I think you still got the lines wrong. The fuel filter line goes to the bottom and the return line to the tank hooks up to the fuel pressure regulator. Also you will need a fuel pressure regulator to adjust the right amount of fuel pressure. An inline fuel pressure gauge is your BEST FRIEND! Recharge your battery homeboy!
bloodspread
part of my problem was the CAS was not connected well, I connected it and turned it I could hear the injectors pulse, on the ecu I also get a code 13? one long blip followed by 3 fast blips. well now I get gas to the cylinders but it still doesn't start, any other ideas? thanks for the help so far.
bloodspread
ok, so I found the plug for the sensor that gave the code, it was loose so I connected it and im getting no codes, but im still getting no spark. any Ideas?
I have a bet with a friend that I could get the car running by the 26th of September. If I could get it running he would buy me a tank of gas
Minuszero
Car: s13 (1990)
check all your grounds, plus the one for your ignitor
Minuszero
Car: s13 (1990)
also was the car an automatic?, if so there is a plug on the side of the fuse box that is big, grey and has 2 wires going to it. If it is not pluged up to anything, like mine was, I had to splice them together......hope this helps and if you do have that empty plug and are weary of doing that just let me know and i will take a picture and send it to you to make sure thats the right plug so you will not f- something up.......I had to do it to mine because with out it it did the same thing
virus77
Car: 95 S14, 71 240z, 97 e320
you did connect all the intercooler and intake piping right? just checking the obvious since the previous pic had no piping lol
bloodspread
I havent been able to check the wiring lately because i worked 2 10hr shifts at work. my question is do I need the intercooler piping for it to run? I seen people turn on the engine without the piping, it would run like **** but it would still run, I'll try to take a look at everything tomorrow
plus im getting no spark, I checked
bloodspread
I checked the grounds before the sun went down and they all look good.
Minuszero wrote:also was the car an automatic?, if so there is a plug on the side of the fuse box that is big, grey and has 2 wires going to it. If it is not pluged up to anything, like mine was, I had to splice them together......hope this helps and if you do have that empty plug and are weary of doing that just let me know and i will take a picture and send it to you to make sure thats the right plug so you will not f- something up.......I had to do it to mine because with out it it did the same thing
can you email or post up a picture of the wires since im not too sure of this cars history. thank you very much
bloodspread
she runs thanks for all the help
virus77
I'm just curious, what was it?
rivaracingrb25
Car: rb25det powered 240
kinda hoppin in but im not getting spark in my rb. any opinions?
bloodspread
my problem was with the 2 green relays by the ecu. they were unplugged and I had to take everything out of my car to look for them. lol
