S14-NEO wrote:well from what i have heard the wiring is somewhat different in regard to comparing them to that of the S1 and S2 RB25. for starters the wiring also includes circuit for Traction control system and ABS. both of which are fed through critical parts of the harness that need to be bypassed in order to properly run. again this is mearly what i have heard,(if i actually had the manual i would be able to find out for myself). and TRUST ME, when i DO find it or whomever find it and sort out the differences i will be posting a "how-to" on everything. this amount of trouble i have gone through is total and i dont want to have to worry about anyone else going through this freakin hell
Wiring the neo motor is easy... Just a bit more tedious work.... All you need is the ecu wiring diagram which can easily be found. Unravel the harness and trace all the wires. Don't worry about the TCS System and other junk. You can isolate those circuits and remove them from the harness...
Tell me what's wrong with the harness and maybe I can give a hand
-Bluefire
