My radiator died...should i get an All Aluminum Radiator???
Xneubien
Car: Cars, Computers, Internet, art, sculpture
My radiator got a 3" crack in the stupid plastic top today...and im thinking about upgrading to an All Aluminum....what are some good brands?
NISTECH
when you replace the radiator recommend a t-stat and a rad cap. the radiator cracked most likely from excesive pressure in the system.
Xneubien
ok..i just ordered an OEM raplacement since i found one for $119 shipped..Ill get a better one when i upgrade the engine
Xneubien
Well lets just say it blead to death
powerdrifter
Car: drifting, engine tuning, music
Sounds to me like you should've replaced (or upgrade like I do) the thermostat and radiator cap. These are the only two things that can rust and get stuck in a closed position to hold in pressure. If that pressure was suddenly released and it was to hot and pressurized, yeah, I could see the plastic radiator busting open.
drft_07
Koyo is a good brand if you decide to get a new one.
powerdrifter
Hey 98KA24DET! What is it with you and the word "death, died, bled, etc." Get a life. These are real mechanics talking, who actually race our 240 on a real track, not the streets, using real mechanical lingo. Get serious in this forum section or get bent!
BenTaylor200
Obviously you've never heard of personification... i.e. the attribution of personal qualities to an inanimate object.
Nothing wrong with saying his radiator 'died' or 'bled to death' perfectly acceptable use of grammar in my book ;)
powerdrifter
that's right! IT DIED AND BLED!
C'mon, back to the subject. If you have an SR20, you have lots of JDM options to choose from. with a little imagination, these can be made to work on the U.S. 240SX. If you have to get a us radiator get the heavy duty on with an all metal contruction. Most aftermarket companies offer this as well, very easy to find. try 1-800-radiator
Scott McLellan
Be Cool and Griffin are good.
tinted
Car: Computers
Ya I just came to this thread to suggest a Griffin, the Nasacar one
http://griffinrad.com/winstoncup.htm
lbrowne
If you had a life you wouldn't be on here correcting his english when we all know exactly what he's talking about. :)
Back to the original poster/author, how many miles did you have on the stocker? I'm trying to figure out how much life is left in my stock radiator. I have just over 100k miles on it now.
goixiz
Car: Cycling and cars
If you have an SR20DET and do not have a FMICthen the stock radiator from USDM will not workyou need a JDM one
KOYO makes one for the SR20
or you can go to a jukyard to measure some american cars and then see which one fits and get the all aluminum version made (cheaper)
S13240
goixiz wrote:If you have an SR20DET and do not have a FMICthen the stock radiator from USDM will not workyou need a JDM one
Lots of guys use their ka24e/ka24de radiators for the swap with no fmic. I for one used my ka rad with my smic on my sr and everything worked fine and gravy. You just have to find the right hoses or you can order the kit straight from heavy throttle.
robertwb70
Car: 72 datsun truck=PL-521/on 85 frame Z-24eng+cam+ported+weber38DGAS
my 1992 just ruptured the stock radiator plastic tank at 197,000 miles
there's this new stuff called anti-freeze-nothing will rust with it-besides rust is a small problem-the corrosion will eat all aluminum parts before rust is an issue-anti-freeze also stops that too
