You guys know you can hit over 1400 MPH withOUT a gameshark?
If you get the Toyota GT1, and then go to the test track.
Set it up like the following:0 downforce in the frontFULL downforce in the rearfront suspension stiff as you can make it (spring rates very high, etc)rear suspension as loose as you can make it (very weak spring rates, etc)front ride height as tall as you can make itrear ride height as low as you can make it
Basically, set the car up like you want it to fly. Go around the test track, and the front of the car will lift. It will lift so high, the rear tires will even lift. When the rear tires lift, the tach will peg, and MPH will go up insanely!
Anyway, have fun with it
