'92 R32 GTSt
Go fast ****RB25 (stock bottom end)RB25 5 speed w/OS Geiken undamppered tripple plate clutchHKS 264 in/ex cams with matching cam gearsTomei valve springsTomei headgasket (stock 9:1 compression)ARP HeadstudsRB26 oil pumpRB26 individual throttle bodies and surge tank using port matched adapter to RB25 head100mm intake piping80mm intercooler piping (ebay special)4'' (4 core?) intercooler (ebay special)Full exhaust with RSR catbackRB26 D-jetro Power FC with boost control kitStec top mount stainless manifoldTwin Stec 50mm wastegates heavily portedHolset HX40 turbo with 19cm ex housing :headbang:
Fuel Stuff2 walbro pumps out backAeromotive FPRTomei fuel rail-6 stainless fuel lines and fittingsZ32 fuel filter****ty *** no name 850cc-860cc injectors (free, so yeah)
Handling/stoppingCusco Zero coiloversSuper duper shiny JDM tight drift spec Mines strut tower bracesR33 front brakes with slotted rotors all aroundStainless braided brake linesCusco brake master cylinder stopperCusco 2 way diffWhiteline adjustable front castor armsAdjustable rear Upper Camber armsAdjustable rear toe arms Alloy Rear Subframe collars (pinapples)Tomei HICAS deleteStreet tires are BFG KDW (new tread) and I rotate through different drag radials a lot
Other stuff (sorry for actually listing some of this **** : )Oil cooler with thermo-switched e-fan Oil filter relocation kitRear mounted optima red top battery6000K HID'sC's short throwSecret Squirrel hidden shift light
This pretty much sums it up
Car is taken apart now, has a stock RB25 in it, and sold. I'm on my way back to the states, and the drivetrain is packed up into a few gorilla boxes, so hopefully it'll find it's way into something before not to much longer.
Modified by Cjmartz2k at 12:54 PM 9/21/2009
