Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Jun 16, 2009 6:34 am
The idle heat output is ~~ 10 HP or 120,000 BTU/hr2,000 rpm cruise is 3x or 360,000 BTU/hr.Acceleration can be in the Millions, but few accelerate for more than 30 seconds................so it only adds 25,000 to prior to acceleration heat level.
Now driving up an incline or mountain can be severe due to time!
Obviously 1/3 goes out exhaust and 1/3 in conducted/radiated away to unhood/hood/body/transmission housing, leaving the cooling system/radiator to get rid of the rest [1/3].
Often much can be gleened from data logging* [real exact coolant temperature] from a COLD start [<100F] to warm up vs seconds/minutes AND RPM in PARK no ac, then doing the exact same thing with ac on [adds 3 HP or 36,000 BTU/hr.
With a +- 1F accuracy you can see in data when the thermostat opens.
* with Consult or other software and OBDII adapter/laptop.
When you replace radiator be sure to visually check condenser for air blocking bent fins, whether auxillary condenser fan works [controlled by ecu and HVAC computer thru ecu], replace upper and lower heater hoses and thermostat [usually fails open = no warm up but helps in winter].
Luckily the cooling system is 90 year old technology so every radiator shop can diagnose often better than dealers can.........not their specialty!
The problem is the rad shop may not have Nissan specific OBDII test equipment to accurately read coolant BUT much can be done with an IR temp measuring gun but spot on accuracy is lacking as the hood must be opened to read coolant and that will change things SIGNIFICANTLY!!!!!!!!
