qship96 wrote:Sounds like it is stuck in failsafe mode to me {locked in third gear} usually an electrical problem, check operation of throttle position sensor and run diagnostic using dash screen method outlined here on the forums
how do you run a diagnostic using dash screen method, and what exactlydo you mean by dash screen(climate control screen?!) and what areyou running a diagnostic on, the transmission? please help and dont sayuse the search button because i havent had much luck with it!what electrical problem could i have? i plugged in all the connections correctly where they plug in at tail shaft of transmission and the only other plug is the one that plugs in to bellhousing end by starter.
i dont know if anyone remembers or not but i spoke of a clickingsound coming from transmission when key was in on posistionbefore i put fluid in it,some thought it was normal and normallyisnt heard because transmission is usually full of fluid. well i can still hear it slightlydont know if this has any thing to do with it
