Justin88na »
https://forums.nicoclub.com/justin88na-u143076.html
Sun Jan 24, 2010 10:14 am
Ok, so about 3 months ago I bought my first Q45 and I have loved it ever since! Even though when I got her she wasn't in the best condition, I knew it wasnt going to cost all the much to fix her. I have pretty good knowledge base and a bunch of experience so I wasn't afraid of the costs involved since I would only be paying for the parts and I have become very good a finding cheap parts.
When i first got her she was idling really rough and i knew there were some quick fixes to take care of the problems. I performed an oil change with motor flush, gave her some Chevron Techron to fix the injectors, and put my Z wheels/tires on because the original ones were gone(inside front wheels where worn to the wire mesh). Then I cleaned the MAF and connection. On top of this I installed my Z's K&N because the Q's filter was nasty and the Z is just collecting snow right now.
I noticed a big increase in smoothness and the grip from the upgraded wheels/tires made a huge difference in all handling aspects. Great! Now off to clean her up. Gave her a thorough cleaning and spent 2 hrs getting all the pine sap off her exterior. Now she was was getting up to par.
Took my first road trip with her on thanksgiving all the way to New York city. It cruised on the highway very well but was still giving me slight hesitation and unevenness at light throttle, especially going up very gradual hills.
So figuring it was the IACV and dirty injectors, I seam foamed the engine, took the Idle air control valve out, cleaned it and reinstalled it. Also, I changed the oil again(what a b**** it is to get that filter loose!)
After that, I installed a new fuel filter and fixed/removed the aftermarket security system that was making my interior lights flash for 60 sec when opened or closed the doors. Great! Things are getting better!
Unfortunately it did not get rid of my engine issues completely, however it did help a lot. Instead of at idle and shaking like it has highly aggressive cams, it just mildly vibrates. Back to the drawing board.....
So this weekend I was able to OHM everything and the results are in!I need one injector completely, it had no resistance at all and two are starting to go, giving me 23 ohms. All the rest of them were at 14 ohms. On top of this I checked the knock sensors and both were in the 250-280 range. Which means I'll need a new set of those as well. So at least I know exactly what is wrong with the car now. So this coming month I will be getting some(4) used injectors, get them professionally cleaned. Order some knock sensors and also order all of the hoses that are under the intake manifold. I figured I would replace those while I had the intake off.
So that about covers the mechanicals. Now to the suspension/brakes and wheels.
Like I said the original wheels that came with the car were highly worn on the insides, so I looked into the issue yesterday and it seems my tension rod bushings are shot and making my new wheels/tires wear extremely fast as well. So I will be upgrading them shortly to urethane Z32 bushings and getting new tires for the fronts.
On top of this the brakes needed replacement so I replaced them with new rotors and Axxis Metal Master Pads. I highly suggest these on any car. I have had them on my 5 series and my Z and have been nothing but happy. Low dust, great bite and awesome modulation.
Well, thats all for now. Take care and hope this gives you guys some motivation to work on your G50's!!!
