My Q is eating alternators
bluedolphin326
Car: 1994 Q45
Ok Guys,My 1994 Q45 is eating alternators. It seems like #3 has gone out. I have noticed that there is a small motor in the top left hand side of the engine that keeps running. I didn't notice it until I went to start the car yesterday and the battery was dead, after sitting for 12 hours. I got the car jumped and was able to drive home (15 miles) with no problem. When I got home and turned the car off, that little motor was still running. I let it run for about 15 minutes then disconnected the postive battery cable. This is my only car and I needed it to start in the morning. I reconnected the cable this morning and the car started right up. It got me to work and again, that little motor was still running, so I disconnected the cable again. Another thing I noticed is that the ABS light came on yesterday morning. Could that be related. Any help is appreciated. I really need this car to last a couple more months....
ThanksMichelle
Rex
Car: None
A couple quick questions ...
* Are you ising an OEM alt or an "Autzone" remanufactured?* How old is your battery?
bluedolphin326
Car: 1994 Q45
A couple quick questions ...* Are you ising an OEM alt or an "Autzone" remanufactured? It is a "rebuild" from "Advanced"* How old is your battery? - less than 6 months
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You need OEM form Joe.
Hopefully battery does meet OEM minimum standards.
Modified by maxnix at 6:36 PM 7/19/2006
bluedolphin326
Car: 1994 Q45
Can someone tell me what that little running motor thing is? It is in the top left corner of the engine compartment. It just wants to run all the time. If the alternator was bad again, would my car continue to run like it is doing?
qship96
Car: 1996 Infiniti Q45
abs pump
bluedolphin326
Car: 1994 Q45
Can I disconnect it and still drive safely? I have a 3 yr old son in the car with me most of the time. I really do appreciate all your guys help. If I can disconnect it, then you know the next question, How do I do it??
Q451990
I'm not sure on the 94-96, but on the 90-93 there is a black cover with a couple of relays under there. It was pretty common for those relays to stick closed causing the problem that you describe. I would try replacing the relay(s) first... You may be able to isolate the problem next time by giving the ABS actuator a good "whack" to free the stuck relay...
Good Luck!
Heath
bluedolphin326
Car: 1994 Q45
THANKS!! I am going to go check them at lunch. That would be great if that is what it is. Thanks again for all your help. I will let you know what I find out.
Q45tech
Alternators [even oem rebuilt units] are not designed to recharge dead batteries.............sure they will do it a few times but at a serious loss in durability......decreased operating life.
Good time [12 + years] to change both ABS relays and the blue starter relay and the traction control relays [if so equipt].
ABS relay failure may be telling you something about the type and status of the tires used on Q over the years...........too many ABS activations from harder than oem tire compounds [greater than 200 treadwear index].......or just number of starts, ABS tests, miles, etc.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
I have a OEM rebuilt alternator you could have for $70. It's almost new.
qsiguy
Car: 1994 Infiniti Q45 Turbo
When my alternator went my ABS, SLIP, and TCS OFF lights all came on. My ABS is fine, sounds like yours is having a problem. And your alternator is likely burning out because it's trying to keep recharging your battery like Tech said.
I don't personally have a problem with rebuilt alternators as long as they have a warranty as I have used them many times. I would guess 1-2 out of 10 will be junk. That said... I wouldn't recommend them for a Q due to the difficult R&R as compared to something like an old chevy truck where you can swap it out in 30 min. I'd rather install a used OEM than a "new" rebuilt/remanufactured in my Q. Get Denvers alternator if you need one, a new one is $307 from Joe (Scottsdale Infifnti, http://www.everythinginfiniti.com). I got a used A/C compressor from Denver and just got it installed last weekend and it's running like a charm, nice a quiet. (thanks Denver, by the way!)
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
Q45denver wrote:I have a OEM rebuilt alternator you could have for $70. It's almost new.
drop me an e-mail [email protected] i'll take it if blue d no wantjames
dsagers
Do you have an aftermarket stereo system?
FDR Dippin
Car: '90 Q
Where is the starter relay located?I have one, now just need to drop it in.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
FDR Dippin wrote:Where is the starter relay located?I have one, now just need to drop it in.
Up near the ABS thing on the passenger side, blue box.
FDR Dippin
Car: '90 Q
Cool
elwesso
2007 BMW M Coupe
BTW, if you want me to get your other account (your JTmoney 2003) working, fire me an email.
