My Q failed SMOG....and it stumbles at 25mph
evil_panda
Car: 94' Infiniti Q45
Hey guys my Q failed the Emissions portion of the CA Smog. :mad: I have no clue what made it fail. I just replaced the fuel pump and filter. The only thing I think it may be, is the the IAC Valve. There is a hose on the IAC Valve that doesn't look like it is completely connected and it doesn't have a clamp on it. Could that make it fail. Also the car starts to stumble only at low RPMs at around 15-25Mph. Can that be from the IAC also. HELP!!! :confused: I need some guidance.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
What RPM range does the engine stumble at?
The testing station tells you what part of the test failed so post up the results.
Put that hose where it belongs with a clamp and see if you pass the (Useless) test.
evil_panda
IT failed the NO(PPM)
15 MPH Max:475 (677)
25 MPH Max:478 (773)
Q45tech
NO is always EGR related, as it is on every gasoline car on Earth!
Usually clogged [or partially clogged] passage system from lack of mainteance.
evil_panda
So Replace the EGR Valve? or clean it.
Q451990
The carbon usually clogs the port in the plenum that's fed by the EGR valve. It's not unusual to find it nearly 100% plugged up with hard crusty carbon. The preferred method for cleaning it is to remove the plenum and clean the port with various brushes, drill bits, dental picks, brake parts cleaner, etc. You can probably clean it with the plenum in place if you remove the throttle body and figure out a way to get paper towels in there to catch all of the debris before it falls into the runners, but it would be tedious.
Heath
Infinitiguy19
He could use a electric vacuum to prevent the crap from falling into the runners. But like Heath said if its really plugged up its far easier with the plenum off.
Q45tech
Hard dental tools often necessary, many times drill bits, or homemade roto rooter from a old piece of throttle cable splayed at end and battery drill. Depending on oil and air dirt the carbon can get harder than concrete.
Pictures should be taken for public display by name to prove the lack of cleanliness of many owners
evil_panda
Thanks guys, but will that solve the problem with it cutting out at low speeds? 15-25mph thats prob between like 1500-2500 Rpms, thats just a guess.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
An EGR flow rate that is below spec would increase Nox.
Real quick lets cover some theory...
Oxides of Nitrogen are caused when combustion chamber temperatures increase beyond a specified level. The egr returns a small amount of exhaust gas into the intake stream in an effort to cool the combustion chamber temperatures. Egr flow only occurs under light to moderate load so under the conditions you are asking about would fit the criteria for an EGR flow function issue. If flow were restricted enough to cause you to fail an IM240 it really should have set a check engine light with a Egr function dtc.
While carbon deposits are very common (it is a cool running V8 after all) and some serious elbow grease will be needed to undo years grime this job is going to require a bunch of tools and about a weekends worth of work for a first timer.
You have to test the egr function. Following the directions in the EC-FE section of the FSM to verify operation of the egr system.
evil_panda
Well it just occurred to me that is the car stumbles at 25 mph, How the heck can the smog the car accurately?!?!?
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
evil_panda wrote:Well it just occurred to me that is the car stumbles at 25 mph, How the heck can the smog the car accurately?!?!?
:wtf2:
evil_panda
yea the guy at the test station said, "your car was stumbling at around 25mph, but I got it to make it through the test"..I was so pissed that I ignored the main factor in the problem.
