My project-White Lightning
cody180sx
Car: s14 rb25det fully built 550whp coming soon
So i got my project underway sorry no pics yet all we have is a cell phone. Blacktop S13 good amount of mods. Alright reason for the build and/or fix about a month ago transmission starts acting weird on me, normal driving everything is alright but at full throttle ether its blowing the tires off are the clutch was slipping really hard to tell. Well long story short, wasn't the tires i adjusted the clutch pedal and it grab hard are something and it broke, real weird situation i still don't know what really happened until i fully remove the transmission. I do know this i pulled the starter off and dear god it IS a fried clutch, strong smell, it was sitting at our shop for a month and the smell was very strong hit me like a ton of bricks.
So I've already removed the drive shaft and most of the bolts from the transmission 2 are in a tight place near the down pipe near the turbo P.I.T.A. So here is a question i can get a j30 diff, axles, and hubs for like 120 bucks good deal but they are a 93-94 models by what i was reading this diff and axles will work but what about the hubs then i can swap it to 5 lug by using the j30 hubs and brakes
Modified by cody180sx at 1:00 PM 2/23/2009
Modified by cody180sx at 1:23 PM 2/23/2009
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
A short search would have helped you, but yes, you can use q45 5 lugs and brakes. Proven all over this site.
zerosearch Go here and type "Q45 brakes".
cody180sx
that had nothing to go with j30 rear brakes. now i have come across just popping the bearing out and putting the s13 in but as far as i can see it works for the front, what about the rear
Modified by cody180sx at 12:59 PM 2/23/2009
cody180sx
So started to pull the transmission and I'm stuck the top of transmission is hitting the firewall and i tried loosening the motor mounts still couldn't get it to drop dang it. I'm thinking of dropping the sub-frame a little and trying it that way don't know out of ideas for tonight. So i think I've got it down on what I'm going to do. I'm getting J30 hubs for the front press out the bearings and put in s13 bearings and just buy the bolt on 5 lugs for the rear and for my diff i'm getting a 93 or 94 J30 diff. My brother ordered my clutch for my 21st birthday so i should be seeing that soon Exedy stage 2 3 puck. Gonna get a buddy to come out tomorrow are Wednesday to take pictures of what has been done so far.
95silvia14
Car: 1995 240SX, 1993 s13 coupe
dito
SR20DET.240
Car: 1989 S13 w/ Redtop
I had the same problem with getting the transmission out. We had the car on a lift and jacked the motor up until we could pull it out. It was a very tight fit. I ended up putting an Exedy stage 2 clutch in mine, I am pretty happy with it. I would recommend keeping the stock flywheel though, I put a fidanza lightened flywheel in mine and now I am having stalling problems. Good luck with the build and post up some pictures when you get a camera.
cody180sx
yeah mine is on jack stands so a little harder and the jack is holding the trans up or to catch it really don't know if i can use it to jack the motor up also. i'll figure out something. I'm gonna take a hammer to the fire wall so that doesn't happen again LOL.
cody180sx
cody180sx
not really a good update but something. Buddy is coming maybe tomorrow with the camera. I helped another friend move his vw bug so he let us borrow some snips to cut the brake dust shield that's about it are shop is 15 miles way from were we live so we could not stay long tonight. Mainly we analyzed the problem of the trans hitting the fire wall so tomorrow we are borrowing a cherry picker and load leveler to raise the motor a tad to get the transmission loose. Saturday we are heading to panama city to check out a junk yard maybe we can find something good.
DRS_S13
Car: 1989 nissan 240sx coupe
dang cody this is dustin. Hit me up tommorow ill go out to the shop and see if I can give you a hand.
RustspecS13
Car: '74 260z and '88 300zx turbo
I just did a clutch job on my 240 a couple weeks ago, and all you have to do is tilt the motor back. I put a piece of wood on my jack and pushed up on the harmonic balancer. Not that hard, just enough to tilt the motor. Although I didn't need to do that to get the transmission out, only when I put it in.
But trust me, if you have an engine hoist, PULL THE MOTOR. Its not that much more work at all, and I spent 5hrs putting the transmission back in. That was just going from new clutch was just installed and transmission laying out of the car, to one/two bolts holding it in. Its a GIANT PITA. And Ive done it a few times.
I did it the same way your doing it now, on jack stands in my grandpas garage. If I had known my neighbor had a engine hoist i would have used it.
You did take the shifter out too right? If you didn't take off all the boots and then take the snap ring that holds the shifter in and your set.
If you take the motor out, take the ps pump off the engine and tie it to the car, and same with the AC if you have it. Other then that its really easy.
~Alex
cody180sx
yeah that was the next move was to pull the motor or jacking the motor up. i couldn't do anything last night went to the emergency room kidney stone most god awful feeling ever thank god i passed it later that night. If there was a list that allowed grown men to cry that would be number one. Yeah dustin i'll hit u up me and brent could use some help.
cody180sx
So update, removed the transmission tonight finally and the pressure plate. All i can say is damn the clutch disc exploded and disintegrated. I finally got some really good pics but my computer will not read the sd card for some reason but i did get some with the cell phone. I received my monster clutch yesterday Exedy stage 2 3 puck nastiness LOL.
Oh BTW, I'm thinking maybe just welding the diff and saving some coin. Gonna buy a J30 diff and re-shim it, for when i break the welded one.
Pics!(More to come soon!)
My car.
ThuG LyFe
Car: 95 S14
lol love the license plate.
steamer1227
Car: 1995 Nissan 240sx KA24DE
i like mountain dew too. does that add extra ponies or just for the shows.
cody180sx
well originally it started as a joke because someone broke my overflow tank but everyone thought it was funny so we left it. It is the first thing everyone sees when i pop the hood not the hks bov are the intake just "whats the mountain dew bottle for," to date one person knew what it was for and hey it does what i need it to. If the think that is ghetto you should see the pipe i used for the intake side because mine didn't come with it, the one that goes from the intercooler piping to the throttle body. The first part is rubber then a metal pipe about 12 inches long with a 45 degree bend back to rubber I used a chrome shower head for like 4 bucks
Yeah the tag was a joke too everyone wanted something cool i wanted something funny a lot of people don't get it.
Modified by cody180sx at 12:54 PM 3/2/2009
MastaYu
Car: 92 Nissan 240SX SE HB
nice bottle
Hoffman5982
Car: '95 sr20det 240sx
hey are you the one with the white 240 that has spray paint all over it?ive seen you in dothan before.i have a red s14.you probably saw my old s14mit was burgandy.im friends with jubby and dustin
cody180sx
yeah most the paints off now i've see two red s14s one belongs to dan and the other one an older women drives i think. I worked with jubby, mine and phillips sr's are why he bought a 240sx with a s,r and dustin commented in this post earlier.
Update did some shopping today purchased a new slave cylinder, wheel bearings, and master cylinder. Wheel bearings and master cylinder will be in tomorrow. Took the new throw out bearing to a shop and had it pressed on, and talked to a buddy about welding the diff .
Modified by cody180sx at 5:38 PM 3/2/2009
Hoffman5982
yea i got it about a month ago,and i had my other one for about a year and a half.im hoping to get an sr this summer,but that could always change
cody180sx
i would be happy to help you if you need it, putting the sr20 in is not that bad really just time consuming.
Hoffman5982
cool,and yea it looks pretty staright forward.ive been reading a bunch of different swap guides.last time i talked to jubby he was still looking for a new 240,did he ever find one?
cody180sx
yeah a blue kouki i think
cody180sx
sweet came across a set of 04-05 touring wheels from a 350z for 100 bucks
