eh? wrote:Strange, I will check mine today. The r33 fsm states .5v at idle but doesn't specify SI or SII. This may be a another difference between the two.
DO you have the rb25det FSM, i didn't see it on your site.
Quote »I just got my car running yesterday. The problem is it idles pretty high, usually 2500-3000 on the KA tach, and breaks up at more than partial throttle. if you give it 1/4 throttle, it will rev up and make some boost. I'm guessing it's either the TPS wiring, a vaccum leak, or some other wiring problem. It seems to run ok otherwise. If it's a vacuum leak, I can't find it. I pressurized all of my intercooler piping, and the intake manifold and I couldn't find any noticeable leaks. I hooked up a gauge and it reads almost 20 in HG at idle. Most of the vacuum lines are new. The modifications are Greddy manifold, Q45 TB, Hybrid FMIC, Apexi filter, and open downpipe. On the Q45 TB, I'm not sure the TPS wiring is right, I'm using the one plug that comes off, anyone know the right way to do it? My stock turbo is wasted, but I don't think that's the problem, it still makes boost. Also, is it a bad idea to drive the car with chipped compressor blades? Will it self-destruct and cause more damage? Anyone have a stock RB turbo or know where I can get a new compressor wheel? TIA[/quote] I'm sure my thinking is wrong but, wouldn't you need something like a S-AFC if you use a non-RB TB?
