You will discover if this unlikely event ocurred when you remove the mast. If teeth are missing from the mast tail, you may indeed have to replace the motor. I had experience once on my Acura where the motor drive teeth were so worn I had to replace the motor. No missing teeth anywhere, though.MattB wrote:I've heard something about broken teeth on the antenna mast...could that cause the noise I've been getting?
