Robry »
https://forums.nicoclub.com/robry-u7116.html
Thu May 15, 2003 6:58 pm
Hi all I own a 89 240sx 5 spd and have 3 problems i cannot just deal with, #1 my speedo sensor just stopped working so now my govener likes to cut my fuel at 6500rpm when i race 2nd 3500-4500rpm in 3rd gear 4th gear and 5th gear when driving normally. The 5thgear sensor is already disconected. when i took a look at my ECU i saw the Yellow wire with the green stripe at the top end of the ecu the 8th one over, I cut that and nothing, govener is still doing its thing , there is another yellow and green stripe wire, but its not comming out of the Ecu its comming down from somewhere else. Can someone help my find the right wire? i think the color of the wires vary from the 92 to the 89. #2 my car constantly backfires, I did a full tune up cap/rotor/wires/plugs/pcv valve/injector cleaner/ cleaned the throttle body and adjusted my timeing perfectly to where it should be. the only thing i changed was my exhaust i have a 2/1.4 inch pipe cat back put on with a ractive fireball style muffler without the resonator, but the car backfired with the stock exhaust to begin with (i think its the injectors more or less because of the problem that follows). and Last when i let my car sit for 6hours+ no matter if its hot or cold outside, my engine wont crank over unless i pump the gas pedal a few times whitch makes no sense because its FUEL INJECTED!!! after it gets going everything is fine. keep in mind there is 168k on the motor. Hope someone can help.
