BadMojo wrote:...I'm also not really sure that I would make use of the adjustability of a coilover. For a bit more than the cost of the Koni's and GC's, I could get a set of Tein's. Realistically, I probably won't ever get a chance to run my car at the track. For a street setup, I just don't see myself adjusting ride height very often.
I too am in the market for a suspension for my street driven, S13. The Tein's are directed toward a drift driver, with the utmost in car control needs. Drift suspensions are stiff, and very non-pliable for the utmost in flat, controlable slides.
The Ground Controls on the other hand, especially when setup with a suitable spring and adjustable strut will offer the suspension travel that is required for street driving.
You mention that you're not going to be going to the track much, and not adjusting the ride height frequently. If that's the case, why are you even looking at the Tein's when GCs and some Koni's will get the job done? Not to mention, they can also be corner weighted. Sort of like getting the ride height adjusted, there is no reason to constantly corner weight it. Just get it done once, and enjoy the benefits of having a truly well balanced suspension setup.
edit: As a side note, I saw that you asked about kgmm springs. I have a set of them on my S13 right now, along with some Bilstein struts. I believe that at least one of the struts is blown, because of the high spring rate and rather severe drop. I never drove the car at stock ride height, but by eyeball... it looks like it's been dropped on the plus side of 2 inches.
As far as predictability goes though, they are very stiff and make for no-surprise oversteer. They're much too stiff for the stock spring perches, but on a coil-over tube, they might provide enough dampening with the increased shock travel.
