gr8bryt »
https://forums.nicoclub.com/gr8bryt-u9354.html
Thu Dec 07, 2006 4:14 pm
Ok Nissan guru's, have a whack @ this. I've got a 90 240sx hatch that I bought over the summer. Shortly after purchase, the starter died and it sat for about a month before I replaced it. Got the car running regularly in about August and everything was fine up until about a month or so ago. I noticed that I was running rich and using up a lot of fuel. I found that the maf sensor connector had a faulty wire connected and used a temp fix of re-wiring it in order to get the car back on the road. Just last weekend I went to the junk yard and got another pigtail and connector to replace the makeshift wiring job aforementioned. The car died on me about 2 1/2 weeks ago and won't even turn over now. I've replaced the spark plugs twice since I noticed the problem; the most recent time was when I changed the pigtail. Distributor cap is good, plug wires are good, fuel injectors are working ok, and I have K&N air filter(came installed already). Some other niconauts have suggested that the battery may not have enough voltage to crank the car, so I connected jumper cables to mine and tried to start it--nothing. The car does have gas in it and I can hear fuel going to the injectors (I think), as well as smell a hint of fuel if I get really close to the valve cover. I don't believe the fuel pump is bad, nor is the maf sensor itself. Yes I suppose it's possible that I got a bad pigtail, but I don't really think that's it. Someone suggested that the car could have jumped time, but I don't know enough to diagnose that. I'm holding out from taking to a shop as a last resort. I'm pretty desperate to get my ride back on the road, so I'm open to all ideas as to what could be going on. The car has the original ka(SOHC) w/ about 168K,Please help.
