joe603 wrote:The quickest fix is to disconnect the rear brake lamp switch or fuse. The computer will not let you apply both brake and gas at the same time. I've seen a mod that interrupts the signal with a switch installed under the dash...
So it will do the same thing, if I pull the fuse?
Is the full write-up available somewhere?
I don't feel really comfortable hacking the wires until I know exactly which wires to cut, and which ones to tie them back into. My knowledge of relays sucks, and I don't want to eff it up.
