My nissan 1991 300zx z32
Z32nico
Car: 1991 nissan 300zx z32
Hi i had bought a 1991 nissan 300zx z32 2+2
5 speed manual w/ 175k miles and a injen cold air intake
And stage 3 clutch for 1700 with rebuilt headers
At first the car had a coolant leak on the back engine hose but i had the owner fix it and when i came back to pick up the car and drive it home on the freeway my left front wheel struts completely broke (3 of them)
I understand its an older car but is this an issue but it has a really healthy motor
And it runs great i just had it towed to my uncles house hes a mechanic
The car doesnt have a title though :( because it needs the smog check (california) -.-
Z32nico
And it has a clean paint job (silver) and bo dents
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Moved this to the Z32 forum.
Welcome to NICO!
NolimitZ32
Your front left what broke off?
Z32nico
My struts that hold the lugnits in place and the wheel in place... You know the bolts that get the luggnuts screwed on to
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Z32nico wrote:My struts that hold the lugnits in place and the wheel in place... You know the bolts that get the luggnuts screwed on to
They are called wheel STUDS not "struts". Struts are part of the suspension that dampens bumps on the roads.
If the studs had been over torqued(tightened) that will happen.
Easy enough to replace, remove brake parts and punch the old ones out and press the new studs in.
I would replace all 5
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Shouldn't be more than $25 in parts. Easily done by yourself.
