My new turbo...Is it worth it???
pr240sx
You need a Stage III T3 wheel to use that housing.You can install the turbo like that, but do not expect high boost numbers. Its like running a semi opened wastegate.
DrFtKiNg180sx
cesar240sx wrote:hi ,i am new to this forum, i have the same set up on my 93/ka24det.i did shave the flange and seals good,and i left the outlet the same, the exhaust shop found me 3 bolts flange for the down pipe its perfect
Can you post pics of your set up. How much boost are you making with your turbo?
DrFtKiNg180sx
Also, does anybody know where I can take my turbo to get it cleaned?
