I have a FUEL PRESSURE REGULATOR. Nowhere near an FMU. My FPR raises pressure per psi of boost on a 1:1 ratio. A FUEL MANAGEMENT UNIT is NOT anywhere near an FPR. It does not regulate pressure like an FPR does. Try using an FMU as your only 'fuel management unit', tar-tar.*B|TCH *
And second, if you know so much about turbo cars, how much power can 740cc injectors support on a 4-cyl motor? 'Roughly' how much PSI does it take? And did you miss the part where I SAID I had 740cc injectors, and I KNEW what my AFR's were when all this was going on? Let me refresh:
eazye2000 wrote:No way I'm maxing out my 740's.. And AFR's are great up until she breaks up. Low 11's actually..
Did you miss that part too? And the part where everyone agreed? I'm running a ridiculous gap. It's an easy fix.racersonly2004 wrote:how do you just assume that its spark blow out when you cant see it.
I'm not touching the rest of your ill-informed comments. You just dug your own hole of ignorance.
I state again, GTFO of KA-T.
*Edit*
Nevermind...WDRacing wrote:Banned
