It has some fun stuff on it. R34 GT-R parts. Super Taikyu parts. Things like subframes, transmission, steering rack, AC and PS, Super Taikyu NISMO ETS control box and switches for wet/dry ABS and torque split sensitivity with A-LSD. 2.8l stroker engine built by XS Engineering a while back with old man Crower parts in the bottom and Reinik cams, Tomei oil pump and NISMO swing pickup in the sump. Heim joints on all suspension arms. A lot of the "special" parts are not available to the public- factory race team use only. Other more typical stuff- twin Bosch 044 pumps in tank, NISMO intake manifold, divided "Twin Turbo" pipe to reduce/eliminate shuffle, HKS GTRS turbos, clutch pack LSD in the front, big intercooler,two oil coolers and accusump, AEM EMS using MAP, and some Autoselect chassis braces under the sheet metal and all over. And a K/N filter in the OE airbox that's fed by a secondary inlet.
I'm swapping out the brakes, buttoning up the general electrical and basic maintenance. R35 GT-R front brakes, Brembo/Lotus calipers with 345x28 rotors on the rear. Going with new wheels, down pipe and exhaust. Found my old R34 GT-R OE seat in my closet that's been there for about 10 years or more. On the lookout for a R34 passenger seat in perfect condition- I installed that in my white R32 GT-R when I got the pair of them. Jack found me a set of used and recently rebuilt Ohlins FLAG-R shocks and springs- that will go on when they come from Japan via container in December. Mackin Industries was nice enough to help me out with getting wheels which were out of stock in the US- Volk TE37SL 18x10. It will need some paint work- one of the fenders has a small issue (but a small paint issue is a full panel paint), and the front lip needs a respray. Some new trim tape for the NISMO sills. Small but visually important.
FYI my car is registered in Florida as a Nissan Skyline GT-R, with NHSTA release papers always in the glove box. I also got a personalized plate- GROUP A.
Two quick iPhone pics of it at Champion Motorsport in Pompano Beach, FL, being worked on currently. They are refining some of the work previously done by RB Motoring/Sean Morris/etc., getting it up to where I want it to be. Some small details, some big changes. It's not the same car anymore.
