vonivo wrote:I have used Hawk Hps pads in the past and they work very well...even better when warmed up.
Why did you go with different pads for front and rear? one set is going to bite harder and one is going to wear faster than the other. Not to mention one pair will / could bite / lockup faster leaving you without the full power of the breaking system.
I want to change my rotors and pads out also for something more grippy like i said i had the hps in the past and they are great untill about 20k and then they stop biting hard especially when they are not warmed up. I guess it wouldn't be that big of a deal to change the pads every 15-20k it only takes 15 min a side.
For the fronts can u just use a c-clamp to push the caliper back in and for the rear is there a special tool or can u just push that one back also with a c-clamp?
wait a second...did you put cardboard inbetween the back of the pad against the caliper? it sure looks like you did...please tell me differently.
Modified by vonivo at 4:47 PM 11/2/2008
the reason i chose different pads for the front and rear is because, since it is a FWD car, there is more weight biased to the front, along with braking pressure since the front calipers are higher volume. so it makes sense to put the track pads in front and the street pads in the back since the rear wont be used as much as the front.
and i know one will wear quicker, trust me, i have done my research and have been racing and modding my cars for years so its not a first time for me, i know what im doing, but if you want anything cleared up you have the right to ask, ill do my best to answer in a way to help you understand better.
it all depends on how you drive on which pads to choose. im usually on the hwy so im at speeds of 65+ everyday so i need to slow down...fast sometimes, so thats why i went with the HP plus, and also because i like to go to the track.
both the front and rear could be pushed out with a c clamp, which surprised me, because i thought i would need that special little bit, but it turns out i didnt.
and no i didnt put a piece of cardboard behind the pad. thats just ridiculous to do, and i feel offended by you saying that lol! but yea, i took the backing plate from the back of the stock pads and put them on the back of the hawks.
and my exhaust is a custom setup. i had mild steel welded up to some 3in mufflers that i bought. they are GReddy SP Replicas, but the are made by Forza Tuning and its called the Sportza...some ghetto ****, but they sound mad good, and i got both of them for $130.
and i will try to get some pictures of my foglight rewire...i swear to god it will only take you 15 minutes to do.
