My New Ride
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
620 LIL HUSTLER
Car: 1977 Datsun 620
i just got my 1977 DATSUN HL620 3 weeks ago.the pics are at my bebo accounthttp://www.bebo.com/PhotoAlbum...84028it needs work
my main problem is the driver-side brake light and driver-side blinker do not work.
Modified by 620 LIL HUSTLER at 7:07 PM 10/25/2008
LilDat
Car: Datsun NL 320, Datsun U320 (the runchwagon) 1972 Datsun 510 wagon
Awesome start, looks like you have a little bumps to work out. I'm guessing a bad ground on your recepticals. Run your wiring harness first then try running a separate ground wire from the signals to a good ground source on the body. It could also possibly be in the switch itself. You could try unhooking the + wire at the passenger side turn signal and hook the wire to the drivers side. Then turn on the PS signal and see if the light works. If so your TS switch is bad. If that's the case pull the steering wheel and you may be able to check the contacts and fix it. If not you'll need to replace. The 620 holds a special place in my heart because that is the first Datsun I bought. Keep us posted on your progress, you've got a good truck to start with. Ken
Lovemys10
Car: 1977 Datsun convertible
have fun with it and try bot to chop it up.
moparvwfreak
Car: 1973 Datusn 620 4 spd(sold), 1973 Datsun 620 5spd, 1993 BMW 325I, various VWs and now a CB7 Accord
not a half bad little 620. good starting point. oh and i want your radio :D
620 LIL HUSTLER
LilDat wrote:Awesome start, looks like you have a little bumps to work out. I'm guessing a bad ground on your recepticals. Run your wiring harness first then try running a separate ground wire from the signals to a good ground source on the body. It could also possibly be in the switch itself. You could try unhooking the + wire at the passenger side turn signal and hook the wire to the drivers side. Then turn on the PS signal and see if the light works. If so your TS switch is bad. If that's the case pull the steering wheel and you may be able to check the contacts and fix it. If not you'll need to replace. The 620 holds a special place in my heart because that is the first Datsun I bought. Keep us posted on your progress, you've got a good truck to start with. Ken
yeah good thing my dad used to work as an autobody repair-man so the bumps in the body will be getting straightend out. i tested the wiers and the ground and by what you said the issue is the switch. another one should be here on thursday. i have some progress body-wise but i put a topper on it. i will have updated pics soon. it is a good thing that it is coming because i need it to take my driving test
Modified by 620 LIL HUSTLER at 7:41 PM 10/28/2008
620 LIL HUSTLER
Lovemys10 wrote:have fun with it and try bot to chop it up.
don't worry i won't but i am going to lower it.
620 LIL HUSTLER
moparvwfreak wrote:not a half bad little 620. good starting point. oh and i want your radio :D
why do you want it
620 LIL HUSTLER
thanks "LilDat" the lights work now.now i know why you have such authority more pics soon
IMH
620 LIL HUSTLER wrote:why do you want it
Probably because it's original.
620 LIL HUSTLER
here are some more pics keep in mind the topper is for functionality not for style.http://www.bebo.com/PhotoAlbum...23018
I am looking for one like this.http://www.cardomain.com/membe...l.jpgany ideas?
Modified by 620 LIL HUSTLER at 4:51 PM 11/3/2008
moparvwfreak
IMH wrote:Probably because it's original.
yup! :D
620 LIL HUSTLER
well i realy dont need the radio anyway it is just there because i dont know what else to do with it
if your serious make contact
[email protected]
Return to “Datsun 620”
