Onescruffyguy »
https://forums.nicoclub.com/onescruffyguy-u193624.html
Sat Mar 03, 2012 10:20 pm
the problem im having is hard to start and get to idle, after awhile of starting it, it will idle if i keep feathering the throttle. once fully warmed it will idle around 1200 rpm. now i'll try to drive and it will stumble then pick up and start to boost around 2700. I could be on wot and it will sound like its boosting or atleast wanting to boost but feels like somethings holding it back. as soon as i lift of the throttle,it completley cuts out and dies. if i unplug the iacv or aac valve and nothing changes, could this mean its bad? also when i unplug maf, or tps ill get a trouble code but no code when i pull the iacv plug. i have a stock ecu, turbo and injectors, walbro 255, fpr set at aound 40, freddy manifold stock tb. and open air bov. vacuum tested and passed, spark plugs and wires tested and passed. maf tested and passed. i cleaned the iacv, it was grimmey and the spring would get stuck open. after cleaning, the spring will return but still no change and the wires are getting voltage. i've turned the idle screw in all the way an back out a half turn but then it wont start at all. its likes it at atleast 4 turns out. also smells like im running rich. dont think its the bov venting cause it doesnt even get a chance to vent before i'll die out.
