The first day i got it I took it to my friends shop, we changed the water pump, timing belt, cam and crank seals, belt tensioner, oil and filter (mobile 1 extended performance) coolant, serpentine belts and rack and pinion bushings.
the things i have on list is the 4 shocks kyb-gr2, dif oil, sparks and valve cover gaskets.
Here are my to toys!
My 97 qx4 and my 91 Montero 3.0
all black n shinny!
Infiniti!
Fog lights with corners modded!
5000k Hid's and 3000k in the fogs, their is a little difference a far as output goes.
But the output on the 5000k is way better that what i had with the 6000k.
Cluter with led mod, i have about 6 led strips inside the cluster and they turn on when I turn on the ignition, after that i tinted the cluster and it gives it a great look.
The pik came out a bit dark but in person it looks great and looks oem, I work at advanced auto parts and they day i got the cluster tinted I took it to get the wheels balanced and when one of my co-workers (who has a 99 pathfinder) was impressed by it, and told me he wanted to get that cluster for his truck, i never told him it was a mod, told him it was oem!
That just waxed look!
A lil dirty!
That's my Q! The thing I want to do the most to my Q is to get 99qx headlights(they are clear mine are glass with lines) and do and fxr retrofit, but if i get Terrano headlights for a good price i'll get those! And some qx56 wheels and i'm done!
