Update:
- Z32 Brembo blanks are ordered to go along with the calipers I alread have- Under plenum hose kit ordered- New knock sensors ordered (cheapest I've found yet that appear to be JECS, gonna try 'em out
http://cgi.ebay.com/ebaymotors...h=003)- Valve cover seal supplies ordered
I'm going to start taking it apart this week to prepare for the stuff above as well as new spark plugs, new accessory belts, fuel pump and probably FPCU, and the metal backed guides. Also need to adjust the shift linkage so will be doing that as well. Should be running great again very, very soon!
About forgot, I'll also be putting on the struts from my other Q as they're still in decent shape unlike the ones on it. Hopefully soon I'll be getting some Tokico's and those springs if we can get enough people.
Will also be modifying the headlight switch to turn off the low beams when the high beams are on. You can see much further when the low beams are off making for night drive that much safer. Its very easy to do as well, already did it in my M30. I just used a little plastic piece from the inside of an 89-94 Maxima headlight switch. Its a little square plastic piece that slides across three buttons inside the assembly (two buttons for high, one for low... two being for constant on and flashing the high beams). Little recesses in the surface of the plastic piece dictate which switch is pressed according to the position of the headlight switch arm. In the case of the Maxima switch, there is simply a recess for the low beam when the arm is forward for the high beams keeping them off. I'll be sure to take some pictures of the process.
Lastly, I'll be doing some exhaust mods... want to let the VH sing a little bit.
