Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Mon Jan 19, 2009 3:54 pm
Look on the overvlow bottle. It's marked "MIN" and "MAX".
With the engine COLD, take the radiator cap off. It should be full to the top.There are any number of siphon tricks you can do to empty the overflow. I'veused a turkey baster with a tube on the end, and I've siphoned. And if youleave the radiator cap off, and the overflow cap on, and blow air in the overflowvent, you can transfer straight back to the radiator (I had a problem for a whilewhere I'd put fluid in the overflow bottle, and it wouldn't suck back). Thesecond time, the bottle would over flow. I used a rubber air pump bulb (likethey use on a blood pressure cuff) to pump air in.
