I have put up the LED mirror casing at back as while as comparing the folding motor's to OEM's. I'll post the comparison later, but right now I am stuck at the part where I have to remove the PIN from the wires so I can get the harness out. This is where I have spend most of time doing without proper tools. I hate it
Day 2:
I gave up with the un-pin the plug, so I do the short-cut way (cut with a wire cutter) and carry on with the work. Then I get to remove the mirror and the strut part that does the folding mechanism. Left is the folding motor. Right is original turning strut.
Fits nicely inside
putting stuff back together
cable pulling
more cable pulling (notice I cut the white plug)
almost done
on car
left - no led / right - led with folding motor
It seems finished, but it really hasn't. Once I get the wiresfix first I will start be doing the passenger side. Then eventually the main eletrical work under the panels.
Modified by insomnia816 at 10:15 PM 12/13/2009
