JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Mon Jun 02, 2008 3:49 pm
Alright, so if anyone here remembers, i dropped my CA in my 1990 coupe last october, went through all kinds of running problems. Had to replace the wastegate actuator and blow off valve, both were leaking vacuum. Finally fixed the running problems to about 95% perfect. Good enough, in fact, to drive from New Orleans to Houston for my dad's 60th birthday at the end of April.
Well, during that trip, the turbo began going out. The center bearing began whining its @$$ off. So i used my economic stimulas check to purchase a new GT28R turbo, even spent another $120 in new gaskets (Cometic exhaust manifold gasket, and a real nifty compressor outlet adapter that has a vacuum nipple built into it). Getting the old turbo out was difficult enough with the engine in the bay, putting this (much) larger turbo in is even harder. Just trying to line the coolant lines up with the turbo already on the manifold was a nightmare. I had to remove the brake master cylinder in order to get the turbo/manifold/elbow assembly into place. I have the SSAC tubular manifold, which sits the turbo down a little bit from stock, and now the compressor side is sitting directly on the drivers side motor mount. I still havent finished the install, so i dont know if its going to rattle on it or not yet.
My question is, what would it hurt to stack a washer or two between the top of the mount and the motor bracket to make it sit a little higher?
