gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Mon Mar 19, 2007 6:55 am
Had the g-ride aligned over the weekend. Had her zeroed out @ 1.75" of fender gap all around and marked off those settings. Then we got a bit more detailed. 1 degree of neg. with 1/16" toe in up front and 1.5 degrees neg. with 1/8" toe in in the rear. Driveability thus far (only a few miles city) is good, but I will be going for a more thorough run later today. With heim joints all around, staggered tires, and ST sway bars the ride is quite comfortable. A bit noisy, but not all that rough on the road. I may consider a little more camber -1.75 front and -2.5 rear once I install the subframe collars and control arm bushings this coming weekend. Turn in is improved, and tire life should still be quite acceptable. I ran these settings before on a dd/track slut, I cant believe how long its been since I have run a track, over 10 years!!! Well, I hope someone finds this info useful as I dont think I have seen to many specs posted.
